need help finding clutch switch wire off ecu
ive had enough of this search buttun not working
im trying to finish installing a synergy 2-step and cant find the clutch switch wire off the ecu, the instructions say blue connector #35, but that location is empty? so im guessing the directions arent for an 02.
you are correct pin 35 for an 02 T/A is not used. That is because for an 02 ta its pin 34
pin connector
ic1 26 c2
ic2 67 c2
ic3 69 c2
ic4 29 c2
ic5 68 c2
ic6 28 c2
ic7 27 c2
ic8 66 c2
engine speed 10 c2
clutch switch 34 c1
pcm power 20/19 c1 pin 19 is ignition voltage pin 20 is battery you probably want ignition
pin connector
ic1 26 c2
ic2 67 c2
ic3 69 c2
ic4 29 c2
ic5 68 c2
ic6 28 c2
ic7 27 c2
ic8 66 c2
engine speed 10 c2
clutch switch 34 c1
thanks, i was about to tear it apart to test the clutch pedal but no fluk meter. figured it has to be somewhere to also cancel out the cruise control when depressed.
you must be a gm tech to find out so quick... if you ever doing side work for nissans i can get you all the info you need on them
