Great new dyno #'s with cam only/true dual lt1
Old 08-10-2007, 01:27 PM
emerica4601's Avatar
Location: king of prussia, pa (home) and williamsport, pa (school)
Default Great new dyno #'s with cam only/true dual lt1
Whats up guys,
Last time I dyno'd, I put down 340rwhp and 345rwtq with my y pipe and sweet thunder setup. The air fuel turned out to be quite lean, which might have been the reason for power loss. I just recently swapped over to 3" true duals with single chamber flowmasters dumped before the axle. That really was the only change since this last dyno.
New results: Temp was the same in the shop as the last dyno... 87°.
Suprisingly I put down 364rwhp and 373rwtq. Man was I pumped up!
Hopefully when I go to the track tonight, I'll be able to cut better than a 2.1 60' because 13.0 @ 108 isnt cuttin it!
Joe
Old 08-10-2007, 01:35 PM
Vicious95Z28's Avatar
Sounds great man, My mods are in the sig. I'd prolly dance around if I saw 360 rwhp out of mine.
Old 08-10-2007, 01:38 PM
daniel6718's Avatar
sure that was corrected? sounds like too much gain to me
Old 08-10-2007, 01:42 PM
hyperzone's Avatar
sweet.. I'd **** a brick if I got even 340! haha..
Old 08-10-2007, 01:55 PM
LT1MAN's Avatar
cool, i bet you were stoked. one time i was on the dyno and it read 286rwhp and something like 957rwtq. it was much too unrealistic to get me excited though..
Old 08-10-2007, 03:16 PM
registered user
ScreaminRedZ's Avatar
That's freaking awesome! Can't wait to see the track results.
Old 08-10-2007, 03:50 PM
InsaneAuto86's Avatar
Nice numbers, how loud is it?
Old 08-10-2007, 04:56 PM
scorpion_z28's Avatar
Nice #'s man
Old 08-10-2007, 05:02 PM
mpe331lx's Avatar
Damn good numbers!
Old 08-10-2007, 05:14 PM
I'm headin to the track tonight, and hoping for mid 12's. and yes, those #'s are corrected ... both times.
Now im shootin for the 400rwhp mark ... its just a matter of deciding how I'm gonna get there.
Old 08-10-2007, 05:20 PM
Scrapin'4.8's Avatar
I hope i can put down them kinda numbers with just my cam. The heads i had didn't work out for me, so i'm back to the stockers.
Old 08-10-2007, 05:22 PM
infinitebird's Avatar
That's pretty good. the 230/236 cam usually makes good numbers with stock heads
Old 08-10-2007, 05:29 PM
That's what i like to hear, i'm running the same cam but with iron heads. A few threads on here and on the impala forum say the iron heads outflow the alum. stock for stock too.
Old 08-10-2007, 06:51 PM
Yes they do outflow the alum by a little, but that doesn't mean you'll make more power with them, since they have more heat issues, which is why the b-bodys run a lower compression.
Old 08-10-2007, 11:31 PM
matt94z's Avatar
Nice numbers. When I had that cam with stock heads, I made 342/334 through a th350 and Moser 12 bolt. That cam will perform at the track as well, I went 12.0's with it and a 3640 race weight. Just spin the motor to around 6600 and shift
Quick Reply: Great new dyno #'s with cam only/true dual lt1
