Question about coolant
Old 08-10-2007, 06:58 PM
growl98's Avatar
Default Question about coolant
It has been really hot around here for awhile so i decided to check my coolant. When i opened the radiator cap i noticed that it had a brown color to it. So i took out the little stick that says coolant only and I noticed that it was brown to. Is this normal
Old 08-10-2007, 07:30 PM
ErikElvis's Avatar
No coolant should be brown. Perhaps someone mixed some green in with the dex to top it off. I would flush it and refill it soon.
Old 08-10-2007, 09:50 PM
sroach20's Avatar
over time the coolant will look like someone emptied their septic tank into your system.
Old 08-10-2007, 11:14 PM
growl98's Avatar
Thanks I will do that soon.
Old 08-11-2007, 12:30 AM
Soul TKR's Avatar
I hate Dexcool... I now use the Prestone Extended Performance Green/Yellow stuff
MUCH BETTER!!!!
Old 08-12-2007, 01:02 AM
ae13291's Avatar
DEXCOOL SUCKS!!!! i really disagree with gm using dexcool yea lik coolent would really last 150,000 miles my ***, dexcool starts producing chunks of brown **** that will clog up the radiator change the cooloent asap
Old 08-12-2007, 12:28 PM
Soul TKR's Avatar
If you do change the fluid, FLUSH FLUSH FLUSH the system out completely! And don't forget the reservoir tank!
