Adjusting Injector Size using LS1 edit
I was just wondering how you change the injector size using LS1 Edit.
I'm in the chart where to do it but there is a formula for the flow rate and I was wondering how you get that.
8 SEC SLOPPY SHOT!!!
Re: Adjusting Injector Size using LS1 edit
not to butt in here but i did the injector flow rate table and i came up with 136% increse on the chart when i ran my car my ltft were in the 20+ range witch means i would have to put my map setting to about 120% doe's this sound right.if i don't change my injector rate my map is at 108% to keep my ltft slighy neg. is there any pros and cons.
by the way the injector flow rate table was based on my setup not your math sorry. stock injectors vs. 30psi svo injectors at 45psi.
