sjones99
08-11-2007, 10:16 AM
I have a stock ls2 with afr 225 heads..what is my compression ratio?
ExTurbo
08-11-2007, 11:52 AM
im pretty sure stock compression is 10.8, cant speak for the AFR heads and what head gaskets you used...hope that helps
sjones99
08-11-2007, 11:57 AM
Stock gasket size..the heads are 66cc.
TA455
08-14-2007, 10:58 AM
According to the Quick and Dirty Cam Calculator the stock compression with 64cc is 10.93:1. Change the volume to 66cc and the compression drops to 10.67:1.
