Running out of injector..
Old 08-11-2007, 02:14 PM
Asmodeus's Avatar
Default Running out of injector..
Tuner was pulling some logs on a highway run, and in 3rd gear.
I have a mild heads/cam car and, currently, stock injectors.
The IDC was at 58% at 3700, 87% at 5000, and 102% at 6000 (and in 90+ degree heat and 80%+ humidity), and the combo makes peak power about 6300.
I will be upgrading to 42's but I wanted to know..
In the meantime, would shifting at 6000 be ok, or would that be dangerous when the temperature drops? or am I risking something? 42's seem like the right choice?
Old 08-11-2007, 03:52 PM
JPH
JPH's Avatar
i would put 42's in it myself. most h/c/i cars making really good hp will usually end up needing 42's.
Old 08-11-2007, 11:44 PM
PREDATOR-Z's Avatar
On a 346 cubes NA more than 30lbs SVO is not needed. Otherwise it only means your fuel supply (pump/regulator) are not doing their job.
30lbs SVO will support 500>550rwhp at proper sustained pressure
Old 08-12-2007, 12:57 AM
Boodyrider's Avatar
Meaning that if you're on the stock pump, you probably ought to at the very least log fuel pressure at the high duty cycle area, and think about a good 255 lph in tank pump at least, with a good wiring approach to supply adequate voltage at high draw
On the other hand, I got a set of flow matched 42s you could make me an offer on.
