Drag Racing Tech - Installed a Burkhart Fab9...pics..
onfire
08-11-2007, 02:27 PM
Chuck's a great guy to do business with...very straightforward.
His Fab9 is built like a tank.
Added bonus was the gears don't make any noise...OEM quiet...until I hit it with the transbrake :engarde:
Weighs 186lbs with fluid and stock backingplates/parkbrakes on it...ready to bolt in. Moser 12bolt was 196lbs same stuff.
Only thing I had to do was drill out all the mounting bolt holes to 0.520" since my LCA's, etc have big bolts, Make a LCA lowering bracket to get a -3degrees on the LCA and make a 0.750" thick swaybar spacer since I didn't use a weld on swaybar....all can be seen in the pics below.
onfire
08-11-2007, 02:31 PM
LCA bracket, swaybar bracket are in here.
frcefed98
08-11-2007, 03:20 PM
:drool: makes my moser look sad:(
plainred02Z
08-11-2007, 03:41 PM
how much does that beast cost?
lethal93ta
08-11-2007, 04:11 PM
other than the back of the housing being squared off it dont look much diffrent than my moser 9 inch with the rear brace installed.
http://www.streetlethal.net/moser/IMG_0406.JPG
http://www.streetlethal.net/moser/IMG_0969.JPG
Steve Burger
08-11-2007, 04:44 PM
I was at their shop today to get some of the stuff I need to install mine. It will be in soon.
NA$TY-TA
08-11-2007, 05:09 PM
Sweet :devil:
tektrans
08-11-2007, 05:58 PM
Nice!! No noise huh?, just like my Moser. :rolleyes:
Looks great!
onfire
08-11-2007, 08:50 PM
http://www.burkhartchassis.com/fbodycomponets.html
mattraypharbor
08-11-2007, 08:54 PM
nice but i think i'll stick with the danas60...Looks realy pretty tho.
onfire
08-11-2007, 08:57 PM
In the big picture either 9 inch is overkill for most street cars since a regular 9 without any extra bracing is stout.
Lots of differences in a FAB9 and a 9 though. Moly vs mild steel :nod: , TA mounting bracket is located on the banjo so it does not hit the tunnel. TA mount has a plate brace if you look at the rear pic. The rear housing is part of the brace...not a brace welded over a pressed pumpkin....all overkill though. :burn:
Looks just like mine. hehehe
Burkhart was great to deal with and its a top notch piece. Glad I bought it.
onfire
08-12-2007, 12:21 PM
I've owned a Strange, Moser and now the Burkhart. No comparision in the quality of the build. Burkhart's stuff looks too good to put under a car. :cheers:
Nine Ball
08-13-2007, 08:45 AM
That is a nice and stout looking axle. I think you installed it more for the show factor :cool:
Very nice I'm jelous of that piece .
MARKSZ71
08-14-2007, 08:55 AM
very nice
N20Dave
08-14-2007, 02:34 PM
Very cool. Got ours today. Quality is awsome and Chuck is great to deal with.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
