brand new spec stage 3+ having problems please help.
Old 08-11-2007, 04:22 PM
John Milner 810's Avatar
Default brand new spec stage 3+ having problems please help.
installed my spec 3+ and havent been able to drive the car because when the car is running it wont go into all gears and even with the clutch all the way to the floor the car still wants to roll. i did not put the shim in because i was told on here not to. do you think this is the problem?
my dad thinks the problem is the shim and/or the slave. i dont think not shimming it is the problem, i just think i have a bad slave.
can anyone recommend anything?
preferably spec_01 or whatever his name on here is, im pretty sure he works for spec....
ANY advice would be appreciated....i would like to drive my car before summer is over...
thanks guys.
Old 08-11-2007, 04:41 PM
Hector's Avatar
Obviously, the clutch is not disengaging. Try bleeding the hydraulics many times. If that doesn't work you will need to pull the trans.
Old 08-11-2007, 05:00 PM
i guess i forgot to mention that we already have bled the the clutch many many many times, i bled it for 2 hours straight one night. so much that all the fluid is new because we bled all the old stuff out.
so knowing that, any other ideas?
thanks for the help so far
Old 08-11-2007, 05:32 PM
nvmy2000ss's Avatar
I would say if the shim was sent to you with the clutch to install it. some people can get away without using it (somtimes this may be due to the fact they have an adjustable master) it sounds like in your case thats not going to work. If you are sure you have blead all the air out of the system then you may have to install that shim.
I had the same problem with my first clutch that I did. after I blead it with a mighty vac everthing was good. Also did you upgrade the hydrolics? You may want to replace the slave since it is pre 01.
hope this helps.
Brian
Old 08-11-2007, 05:54 PM
brad8266's Avatar
You need the shim, it isnt disengaging because because the TO bearing is too far from the pressure plate, hence the reason for the shim. An adjustable master would be a good idea too.
Old 08-11-2007, 06:14 PM
ZoneSS's Avatar
A lot of times using a after market clutch, you need a slave shim. A trany guy told me, the place he worked at, would shim out the flywheel if it had been cut down to a certain amount!
Old 08-11-2007, 06:42 PM
wow, well i guess im just worried about the clutch wearing really fast if i use the shim.
i have read alot about the shim and alot of guys said not to use it because the clutch will just get toasted after like 5k miles...
maybe i should throw it in there and see what happens.....
i cant afford another 800 bucks for clutch and flywheel though...
Old 08-11-2007, 08:39 PM
ZoneSS's Avatar
I put an LS7 clutch kit in mine $399 plus shipping. That includes the flywheel it's a great clutch!!! Got it from SDPC. Scoggin Dickey Part Center. Lubbock TX.
Old 08-11-2007, 09:13 PM
o1m6ss's Avatar
Default shim
the shim shouldn't make ur clutch wear out, esp. if u have an adjustable master. u definatly need it installed though.
Old 08-12-2007, 02:21 AM
Jeff@TotalPerformanceEng's Avatar
In the instruction sheet, it specifically states that you need to install the shim when putting the clutch on a F-Body.
Old 08-12-2007, 08:41 PM
myfast70's Avatar
Agreed. If it wasn't needed they wouldn't have put it in the box. I installed the shim in mine and it is just fine.
Old 08-13-2007, 12:42 AM
NufNuffZ28's Avatar
I have a Spec 2+ and installed the shim. It would still never disengage at first until a couple moderate launches(2500 rpm or so) After that it worked but did not totally disengage at high RM(no high RPM shifting).
Our last ditch effort was an adjustible master(we used a RAM) and it is now working MUCH MUCH better....
Old 08-13-2007, 05:11 PM
thanks for the input nufnuff i will look into that..
thanks to everyone else too.
Old 08-13-2007, 05:31 PM
GR33N GoblinM6's Avatar
since this hasnt been asked... what flywheel are you using? are you using an old flywheel?? it might be out of spec now.. and pushes the clutch further away as well.
Old 08-14-2007, 08:59 AM
no, i am using a brand new spec flywheel.
