ETP 225's and T-rex......
Old 08-11-2007, 07:34 PM
Chris Gage's Avatar
Default ETP 225's and T-rex......
The heads are 11* ETP 225, 57cc, 2.08/1.57 valve, stock bottom-end (minus rod-bolts), and a t-rex cam (exact specs 243/249.5.612/.618 110+s). The question I am having at this point is PTV. I have no issue flycutting but I am wondering if somebody has a similiar set-up. Also, I have a set of .040 cosmetic gaskets but I heard that I may want to use the stock gasket. What is your opinion and explain why.
Thanks
Old 08-11-2007, 08:09 PM
5w20's Avatar
Originally Posted by Chris Gage
The heads are ETP 225, 57cc 2.08/1.57 valve, stock bottom-end (minus rod-bolts), and a t-rex cam (exact specs 243/249.5.612/.618 110+s). The question I am having at this point is PTV. I have no issue flycutting but I am wondering if somebody has a similiar set-up. Also, I have a set of .040 cosmetic gaskets but I heard that I may want to use the stock gasket. What is your opinion and explain why.
Thanks
Im going to say you are going to have some issues there.
Old 08-11-2007, 08:22 PM
Chris Gage's Avatar
That is what I was thinking, I am still waiting to hear back from Cary on this subject.
Old 08-12-2007, 02:51 AM
The PAT WS6's Avatar
aint gonna work bro.
u gotta stick with a stock non milled 243 or 799 casting..
Old 08-12-2007, 02:57 AM
SuperZ's Avatar
Just put some forged rods and pistons in it and have no PTV issues and be able to turn the rpm it will need safely
Old 08-12-2007, 10:42 AM
Chris Gage's Avatar
ETP's offer more clearence then a stock unmilled head, so by saying you "gotta" is a inaccurate statement. I am guessing that you maybe one of the guys that think a t-rex wont work with an aftermarket head too huh?
Old 08-12-2007, 10:43 AM
Chris Gage's Avatar
That is what I am thinking at this point, I would like to get away with just fly-cutting the pistons and then spinning the mottor to 7k no problems as the valvetrain and rod bolts have been upgraded.
Old 08-12-2007, 03:38 PM
santiago's Avatar
i dont know about your ptv but goodluck on the set up and keep us posted on the numbers. sounds like a great set up.
Old 08-12-2007, 04:31 PM
ls2 bait's Avatar
if u do that dont forget the valve angles are 11* on the etp's and 15* on the ls1 head so u will need to cut the reliefs on 11* angles-and u dont want to use ur pretty head to do that.
Old 08-15-2007, 03:42 PM
PewterZ28's Avatar
I have the exact same heads and a smaller cam and kissed every piston even after verifying PTV clearance was around .050. Perhaps it was less than we thought. Anyway, I say the T-Rex is not going to fit.
