turbo 400 wiring help needed
Old 08-12-2007, 12:56 PM
3stgstocker's Avatar
Default turbo 400 wiring help needed
i got a 98 t/a was an a4 car now its turbo 400. i got a hurst piston grip shifter part#3162006 from summit. i need the wiring diagram to hook up neutral safety and reverse lights from the factory harness. im not sure if it has a swith 4 the reverse lights on this shifter going to get it from home now. let me know what i need to do
Old 08-17-2007, 06:33 PM
BJC51984's Avatar
I just installed the same setup as you in my 00 SS. you will need to order and install a hurst back up lamp switch for your shifter from summit, and then cut off that factory big connector you will have two terminals on the reverse light switch, run the light green wire to one and the brown one to the other, for the neutral switch you run the dark green to one and purple to the other and to get your hatch release to work you just connect the remaining orange and black wires together.
Quick Reply: turbo 400 wiring help needed
