throtle body
Old 08-12-2007, 01:29 PM
camaro-94-z28's Avatar
Default throtle body
i hear talking about a throttle body modification how exactly do you do that
Old 08-12-2007, 02:05 PM
BsGreenZ's Avatar
what mod are you talking about...
Old 08-12-2007, 02:12 PM
without actually replacing the throttle body.... i think (not 100% sure doesnt sound plasuable) a bypass of some sort
Old 08-12-2007, 02:25 PM
BsGreenZ's Avatar
the throttle body by-pass??? all you do is by-pass the colant from going throught the bottom of the throttle body and connect the hoses together... not to hard but really not worth it...
Old 08-12-2007, 02:55 PM
oo ok.
Old 08-12-2007, 03:00 PM
LT1Falcon's Avatar
i think it is worth the 2 dollars and 20 minutes. just the fact of knowing hot water is not heating your incoming air is worth the little time and money, even if it doesnt do much good
Old 08-12-2007, 03:21 PM
what to hoses do you connect together
Old 08-12-2007, 03:26 PM
C5042081's Avatar
run the "in" that goes to the TB right into the radiator , just look at it, your trying to Bypass the colant from going into the TB http://shbox.com/1/tb_bypass.jpg
Quick Reply: throtle body
