Should i get new lifters w/ H/C swap?
Planning on doing an H/C swap this Christmas for my car (important mods are in sig) and i was wonderin' if i was going to need to replace the lifters? The car has got just shy of 70K on the clock so would the stockers be fine? Or is it more than just mileage to worry about?
If i do need them, any suggestions?
If your going to have the heads off anyways...why not? I won't be replacing the stock ones yet because I'm only installing a cam and valvetrain this May. I don't want to take off the heads and replace the gaskets/bolts just to replace the lifters.
P.S. I won't be replacing the stock ones yet because I'm only installing a cam and valvetrain this May. I don't want to take off the heads and replace the gaskets/bolts just to replace the lifters.
Originally Posted by Vrbas
Any links to those LS7 lifters? I tried searchin' around the site and it's a bit complicated cause i'm not well educated in the lifter department. Thanks for the help.
http://www.texas-speed.com/shop/item...d=690&catid=50
