Problems with crank pulley install
So, search isn't working. I have been screwing with this for a while, and im not getting anywhere, so im posting. I got the old pulley off, Broke bolt loose easy, even with a 3 arm pulley puller, getting the old pulley off was not easy, but finally i got it. Now i can not get the new pulley on far enough to get the old bolt started to pull the pulley tight to the motor. I have to have it close, it goes on somewhat....
Any suggestions? the pulley is in the oven right now at about 250 degrees backing. gonna leave it in there for 20 minutes and see if that helps.
Thanks, Chris
Thanks, Chris
How hot should i put the pulley in the oven at. I had it at 250... It was in there for 25 minutes. It was nice and hot. Still with a piece of wood beating on it, it wouldn't slip on. Should i try 350? for another 10 minutes.
I tried to find a m16 2.00 pitch bolt longer, and i couldn't i looked everywhere, and they all looked at me like no one in the word would make a bolt this big...
Hmmmm propane torch.....
I'm telling ya...propane torch worked awesome for me....I tried the oven thing first too and it didn't work for me either. Hit that sucker with a torch and it will slip right on....just be careful and don't get it too hot. I actually checked mine by using an old rubber seal I had laying around to make sure it wasn't too hot to melt it.
I threw it back in the oven at about 350 for 15 minutes or so. Got it real hot, had a 2x4 with a dead blow hammer, and got the damn thing on. Wow did that suck.
Thanks guys for posting the help right away. Something that should of been so simple was such a pain...
Chris
Chris
Originally Posted by 98Camarod
It would have been alot easier with the longer bolt, but I dont know where to get one from.
Thanks again
Chris
Originally Posted by Black98Z28
lol im gona try the 350 degree method for 15 mins, this thing is a PITA
