1.6 RRs on 93 vette heads...
Allright, i got a set of 93 LT1 vette heads, ported them and was wanting to get the most from them by going with 1.6 RRs, my machine shop(a verry good one) that i use told me thet with the ratio on the lift the stock springs would coil bind right at the max lift, anyone just strap some 1.6ers on their LT1 and not coil bind or have any issues or is a spring change a must?
Originally Posted by ZONES89RS
Hell, i think i can use those 40$ "Z28" springs that are good to .525 lift then right?
Stock cam, just did some decent port work on the heads before i replaced the head gaskets, ill be picking them up from the machine shop today.
Originally Posted by 1997bird
I would use the ZO6 (yellow spring) part #12499224 that only runs around $60 and get the matching retainer from Comp Cams #787-16 for around $60. This way you have a spring rated for a .570 lift cam and get the added advatages of the light weight spring/retainer package. The installed height will match the LT-1's without having to use shims or machine work to the heads.
175 valvejob with resurface
40 head gaskets
40 head bolts
20 intake gaskets
2 water pump gaskets(WOW)
and i still need valve cover gaskets, header bolts and to replace the opti(under warranty)
