Z06 or 08 Vette-what is controlling dual mode exhaust?
Old 08-13-2007, 06:26 AM
Larry's Avatar
Default Z06 or 08 Vette-what is controlling dual mode exhaust?
What controls the dual mode exhaust butterflies in a 06+ Z06 or 08 C6 Corvette? I have HP Tuner but have been unable to fine any program function. The butterflies open approximately 3500 rpm. What or where do they get their signal?
Old 08-13-2007, 10:25 AM
3.4camaro's Avatar
Vacuum. Like EGR.
Old 08-13-2007, 10:34 AM
kcmags's Avatar
^^^ Yeah ..you can pull a fuse that will keep the butterflies open if you desire.
Old 08-13-2007, 11:01 AM
wait4me's Avatar
I looked thru, i think it is just controlled by a whole different module, not the pcm. BUT it does recieve a rpm signal from the Can bus which originates from the pcm.
If you would like to make it turn on sooner/later, you can buy an rpm converter output box from the street rod guys that you can minipulate the rpm signal seen by the muffler module. But Yes they are correct also, as it being run off of vacume but controled electronically.
Old 08-13-2007, 11:49 AM
Larry's Avatar
Thanks, that's what I was looking for. I know the butterflies work off vacuum but did not know where the vacuum got it's signal. Looks like then there is no way to control it with HP Tuner programming if there is a separate module. Maybe HP will eventually give us a beta file to give control.
Don't want to pull the fuse. I tried that and it's too loud for most of my driving.
Quick Reply: Z06 or 08 Vette-what is controlling dual mode exhaust?
