LS1 Quick Cam Cover Cam Swap Video
We did a cam swap on my Camaro last weekend. Pulled out a 232/236 cam and put in a 236/248 cam in. We made a video of it showing off how easy a cam swap is with our 2 piece timing cover.
I made 2 versions of it. Both are on the larger side. One is compressed and the other is not.
Cam Swap Video 10mb
Cam Swap Video 36mb
More info on the covers can be seen here.
http://www.quicktimeperformance.com/Cover/index.php
And we figured we will run a sale on the Cam Covers and Pumps.
Prices will be on our post in the Vendor Sales Section here:
https://ls1tech.com/forums/showthrea...80#post7605980
Cam Swap Video 10mb
Cam Swap Video 36mb
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I change cams alot. If you don't want to screw with the stupid pulley this is worth it. Only question is can you see how you are lining back up when the cam gear goes back on? I figured you would just mark it when you take it off then just hope you don't smear the mark on the chain or the gear. How did you guys do it? I just like to stare the dots in the face. Just a comfort I guess, but they are tough to see anyway.
Top gun was a good choice for the video.
I was thinkin the same thing. Not doubting you guys, cause its obvious you have it figured out, just curious.
