New LS1 Owners - Newbie Tech - ASP pulley vs SLP pulley
View Full Version : ASP pulley vs SLP pulley
AntiVen0m
08-13-2007, 11:21 AM
is either one better than the other or both about the same...i want to know if anyone has used either one and what their gains are..
WS6Jayson
08-13-2007, 11:50 AM
I've heard only good things about ASP
davered00ss
08-13-2007, 03:53 PM
I like the SLP/March/powerbond pully better than the ASP. They have a larger lip which helps to keep from throwing a belt. If you get the ASP, I would get a KTech tentioner for it. I gained 12rwhp & 12rwtq with the SLP pully.
TXZ28LS1
08-13-2007, 04:53 PM
im also planning on going with the slp pulley!! seems to be better quality i guess!!
bad6as
08-13-2007, 05:18 PM
slp and power bond are the same. the newer asp pulleys are better then the older ones and i think their also lighter then the stocker and slp
RoWDyWS6
08-15-2007, 05:16 PM
do u got to buy a new belt for a pulley swap??
hawaiianpunch01SS
08-15-2007, 05:20 PM
yes new belt 4 the main drive and ac. and i havce never had the SLP but i love the ASP gave me about a 3mpg increase
MikeSomething
08-15-2007, 05:40 PM
Sportin the ASP for awhile now. No problems, no worries. Works just fine. I didn't notice any increase in HP but it helps the motor rev up alot faster...
mcamarols1
08-15-2007, 09:49 PM
do u have to remove, the radiator ect. ect, to install the pulley or can u do it from under the car w/ a lift?
Sideways240sx
08-15-2007, 10:05 PM
you dont have to pull the radiator. You can do it on a lift, in a pit, or even with the front end jacked up.
I personally like the march unit the best. Sfi approved, Fluid dampened. Comes with new gm bolt, black powdercoat. Very nice unit. Id go slp before asp. And i went March before slp. There both gonna do about the same thing, but supposibly the fluid dampened march pulley will not cause the spark sensor's from retarding timing.
Thunder racing is the only sponser that sells the march pulley. Its 199.99 by itself, or 229.99 for the pulley, and both belts you will need. (great deal)
The march pulley seems to be cheaper than both the slp, and asp pulleys, and everyone that has run it absoultly loves it. I have seen dyno's of 12hp, and thats what they claim.
Getting the crank bolt out isn't to bad, getting the pulley off the crank is, and getting the new pulley on the crank is worse. Plan for a long day of frustration..
good luck
Chris
CaMaRo67RS355
08-15-2007, 10:10 PM
Asp!!!!!!!!!!!!!!!!!!!
Smokin00WS6
08-15-2007, 10:15 PM
You are correct sir. SLP or ASP it doesnt matter. Even throw in March. I think you will get the same results no matter where. ASP has the higher walls now too like the SLP. Its a nice mod, I just wish I would have waited to do it when I do my cam next year. You will see on average about 5-10 RWHP gain.
davered00ss
08-16-2007, 05:30 PM
March, Powerbond and SLP are the same pully. The ASP is not SFI approved last I knew. They did also have issues with throwing belts, but that may have been fixed. Throwing belts can be fixed with a Ktech tentioner.
Sideways240sx
08-16-2007, 07:02 PM
I dont think they are the same pulley. The powerbond, or Slp are not fluid dampened.
Chris
SmaknaSS
08-16-2007, 07:17 PM
I have been using the same ASP pulley from my old car and now on this car since I think it was 02. Ive been happy with it and have had no problems with the belts coming off KR ect. ASP is good in my book.
ULTIMATEORANGESS
08-18-2007, 05:40 PM
same here. 5+ yrs. with no problems.
Benjamin Russick
08-19-2007, 02:50 PM
I've had the ASP pulley since 2001 on my old engine and my current one. No issues whatsoever and have never thrown a belt. Got it slightly used with belts for $175...
