throwin sparks out exhaust
Old 08-13-2007, 01:49 PM
CodyZ28's Avatar
Default throwin sparks out exhaust
is this normal or should I be concerned? I was uh, racing this weekend and it was in a dark area and ppl said I was spitting some sparks out of my exhaust? I have no cats btw.
official btw I'm in the mid 12's
Old 08-13-2007, 02:06 PM
speed_demon24's Avatar
If you are throwing sparks out the exhaust that means you are melting your pistons and if you were melting your pistons your motor woulda went boom.
Old 08-13-2007, 04:51 PM
AutomagicLS1's Avatar
Were you on the brakes? Are you sure your y pipe didnt hit the ground? It doesnt sound right. Sometimes when i hit my brakes my car nosedives and scrapes sometimes. When I do scrape I cant hear it in the car its too loud and the wind blowing and stuff
Old 08-13-2007, 05:37 PM
GR33N GoblinM6's Avatar
any chance of getting a video of this? Is it doing it at idle? Any metalic sounds coming from the engine? vibration? done any recent engine work? More info needed...
Old 08-14-2007, 02:02 AM
CodyZ28's Avatar
No recent engine work other than a tranny rebuild in oct. No weird engine sounds or vibrations runs good except the cold idle choppy loop... Sadly no video either
I will let someone else run it and I will watch it I guess.
O ya I wasn't on the brakes, about half through the run doing like 90ish.
Old 08-14-2007, 03:22 AM
under pressure's Avatar
I have noticed this before with power adder cars when under extreme load at upper RPM. More than once the sparks preceded heads gasket failure. I thought they may be due to portions of the gasket sealing ring being eroded and passed out the exhaust. Just my own guess.
Old 08-14-2007, 04:14 AM
CodyZ28's Avatar
Damn think I will just sell it and do my LS1 97 1500 build lol
Old 08-14-2007, 07:08 AM
DaddySS's Avatar
It's way too premature to draw any conclusions....I have seen sparks out the exhaust for many reasons - burning carbon off the exhaust manifolds, muffler material leeting loose, old air cleaners flaking into the intake, etc., etc. If you're not getting ping or knock retard I doubt that you are harming the pistons.
Old 08-14-2007, 05:20 PM
GuitsBoy's Avatar
ive been told my car has shot sparks out the cutouts. I think it was simply carbon coming out. My car has held up for countless miles, WOT romps, and dyno pulls since then.
Old 08-14-2007, 06:27 PM
1998LS1SS's Avatar
I have a friend with a WS6 lid, guttet cats, slp y, and gmmg and while i was racing him a friend tailing us said he saw his exhaust pipe glow. Pretty much stock and his car runs great.
Old 08-14-2007, 10:08 PM
CodyZ28's Avatar
I noticed a slight tick/hiss but I've assumed it to be a exhaust leak at the longtubes flange area.
Old 08-14-2007, 10:45 PM
heavy6.0's Avatar
pull your plugs and check for detonation. it could be a gasket either header or head gasket. carbon build up will also spark under wot due to the heat.
Old 08-14-2007, 10:57 PM
DropTopBird's Avatar
Are you sure its sparks coming out of the exhaust? Ive heard of people with gutted/no cats and a free flowing exhaust shoot flames out their tailpipes on shifts. If I remember, the consensus was that is was the unburnt fuel from between shifts being ignited. Ill try and find the thread.
Edit: Heres one of the threads about it
https://ls1tech.com/forums/showthrea...t=flamethrower
Id say have someone record it on video and see whats really happening.
Old 08-15-2007, 07:09 PM
CodyZ28's Avatar
I asked again and they arn't too bright lol, they said they were orange though and fell on the ground. I'm wondering more of a bottoming out of the exhaust isse cuz mine hangs hella low and i've already ripped it off once on a speed bump... plus it was on the incline of a small hill.
Old 01-02-2010, 02:07 AM
CodyZ28's Avatar
lol I just found founds this. Car has 104K now and going strong.
Quick Reply: throwin sparks out exhaust
