Just got my LS1 Edit(need help)
I have the check engine light on because of the two rear o2 sensors. So i will need to delete the rear o2 codes. I will also need to delete the skip shift code..... Can someone guide me through the LS1 Edit. Thank you.
Re: Just got my LS1 Edit(need help)
To delete the rear o2's I just looked for all the codes that referred to xxxx_sensor 2 and turned them off. As far as the skip shift, do a search
By the way guys, when i go to Program PCM it tells me u have to find a file called FLASH? I dont have any file called that name... so what should i do?
