Does weather affect our cars this much?
I went to Thunder Valley in OK. tonite and the best I could run was a 12.81 @ 108. I am from DE. and race at Cecil County alot where I usually run anywhere from 12.2 to 12.5 @ 113-114.
Elevation is about the same but the temps at Cecil were really good last time I went......around 50-60 and low humidity. It was about 82 and very humid here.
Also, I was in pure street form. BFG Comp TAs and full weight...3550. Cam only, A4, with most boltons and a decent converter.
60's were pretty comparable at both tracks. 1.90's usually.
Stu
Stu
Re: Does weather affect our cars this much?
The track elevations are not the same. Cecil is 320 ft, Thunder Valley is 1054 ft.
The temps make a big difference too. 50-60 is WAY better than 82..
Damn Bob, you're right. I thought Cecil was closer to 800. Thanks. That doesnt scare me as bad.
