random MAP sensor alarm after FAST intake
Old 08-15-2007, 02:02 PM
coolchevy's Avatar
Default random MAP sensor alarm after FAST intake
Guys,
maybe one has an idea what that is supposed to mean and come from. Sometimes when I start the new stroker engine the MIL goes on with a "MAP sensor low signal" alarm. Engine got big heads (ETP 255), a healthy cam (258/258) and 90mm FAST intake. Reading through the manual the alarm explanation does not really make sense. Engine runs and idles well though.
Anyone else have that or what should be done against it?
I am inclined to turn it off via HPT if it is a meaningless alarm.
Old 08-16-2007, 08:56 AM
Black02SS's Avatar
If it is P0106 you can raise the limits so it doesn't not set. This will still allow it to function and not be turned off completely.
Old 08-16-2007, 03:17 PM
coolchevy's Avatar
it is right now set at 10. What would you consider a "safe" value, 13+ or even higher?
