Fast 90 w/ Nick Williams TB?
Old 08-16-2007, 12:13 AM
Restricted User
Zero4488's Avatar
Default Fast 90 w/ Nick Williams TB?
Is it recomended to run a Fast 90mm Intake w/ a Nick William 90mm TB on a stock internal LS1? Cause I want to see how fast I can get my car on stock internals....
Old 08-16-2007, 12:20 AM
SPLATT's Avatar
are you heads/Cam? Do it, people see great results with that setup, stock internal or not.
Old 08-16-2007, 12:22 AM
mudflap1989's Avatar
I don't really know what you mean by "recommended" you money would be better spent of a cam, so in that aspect I don't recommend it, but if you are just asking are far as if it will damage the motor, it will be fine. You will see a power increase, but not much till you get a cam and heads.
Old 08-16-2007, 12:29 AM
Restricted User
Zero4488's Avatar
Well I want to make my car a "full" bolt on car before I do any type of cam or heads....I wanna see what the best power a full bolt on LS1 car can put down. For now I have the LS6 intake and stock TB.....
Old 08-16-2007, 12:59 AM
Reject's Avatar
H/C are technically bolton's lol
Old 08-16-2007, 01:02 AM
Restricted User
Zero4488's Avatar
I wanna do it with stock internals....
Old 08-16-2007, 01:12 AM
JustAnIlluzion's Avatar
some guy on here is running 10s on stock heads and cam, no boost, no nitrous
search it up
Old 08-16-2007, 01:16 AM
Restricted User
Zero4488's Avatar
Well I just wanna see what I can do with my car....
Old 08-16-2007, 01:17 AM
Reject's Avatar
low to mid 13's would be my guess
Old 08-16-2007, 01:20 AM
Restricted User
Zero4488's Avatar
13's? I'm in the 12's already.....
Old 08-16-2007, 07:48 AM
silver01z06's Avatar
is what people are saying is, yes you will gain power with a 90/90 setup but you dont have the other parts to get full advantage/gains out of it. if you havent done a cam or heads yet you can get better gains by doing them first.
Old 08-16-2007, 09:37 AM
PREDATOR-Z's Avatar
If it is for the sole purpose of staying stock internals, the TPIS Oval setup will make more horses than a FAST 90/90 (on stock internals).
Old 08-16-2007, 10:08 AM
Restricted User
Zero4488's Avatar
I'll look into the TPIS one...
Old 08-16-2007, 10:09 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Moving to External
Old 08-16-2007, 12:00 PM
SPLATT's Avatar
well with a heads/cam package you are still stock internal .
Old 08-16-2007, 01:04 PM
Internet Mechanic
BlackScreaminMachine's Avatar
If you crack the seal, its not stock internal. Maybe that arguement can be made of a DOHC motor.
What you are describing is stock short block.
Old 08-16-2007, 02:04 PM
SPLATT's Avatar
i know i was just agreeing with reject that they were bolt ons lol. it was a joke. I think a 90 may be a little much for an all stock internal motor though
Old 08-16-2007, 02:53 PM
Flow Wizard
Tony Mamo @ AFR's Avatar
About 6-12 months back I did a ported 90 FAST for one of the members on this board who is very competitive racing in the SI class.
He picked up 12 RWHP peak but 20 RWHP past peak and was very happy about it for obvious reasons.
A 90 mm FAST is not "too much" for a stock engine....The manifold /TB combo represents an air valve (not a carb) and a less restrictive air valve lets the engine make more power. Everyone confuses this with the old school thinking of overcarbing an engine. That was a legitamate concern because too large a carb would provide poor airspeed, a crappy signal, and not atomize fuel very well (a bad combination).
You could run a 2000 CFM TB on a bone stock engine and it might not make more power than a 1000 CFM piece, but it wont hurt the power curve at all.
I'll be damned if I cant remember his name (the guy I helped)....Im fairly certain it was David and he lived in North Carolina. If I remember I will repost.
Thanks,
Tony
Old 08-16-2007, 04:07 PM
SPLATT's Avatar
indeed. theres your answer guy. thanks for the Correction tony! do you remember the times he ran?
Old 08-16-2007, 05:22 PM
Reject's Avatar
did his throttle response get alittle sloppy now that the air was so free apart from one another? you know just ilke a water valve (i'm talking SOLEY throttle response....nothing else)
