overheating and thermostat
Old 08-16-2007, 06:07 AM
bdaniels's Avatar
Default overheating and thermostat
I got a 1998 SS camaro and im running it without the thermostat will that effect anyhting. Even with the thermostat out im still overheating especially with the ac on what do yall suggest
Old 08-16-2007, 04:35 PM
blade2222's Avatar
air in the system or possable bad water pump
Old 08-16-2007, 07:13 PM
Closed ex-Sponsor Account
autotrix's Avatar
You need a thermostat, put it back in. Check your cooling fans, Radiator cap, fluid levels and for debris caught in the radiator.
Old 08-17-2007, 07:25 PM
ipdking711's Avatar
flush your system, drop in a thermostat and try it out.
Old 08-17-2007, 07:40 PM
ls1_doc's Avatar
Does it do any better on the freeway ? I would check your fans for proper function and the maybe get the radator rodded.
Old 08-17-2007, 11:42 PM
WS6_ALV's Avatar
Im going thru the same issue right now, so im going to replace the thermostat this weekend first.
Old 08-18-2007, 10:50 AM
autotrix's Avatar
Keep in mind that these cars naturally run fairly hot, 208-214ish degrees depending on the outside temp and driving conditions.
