No one knows - - help.
Old 08-16-2007, 04:27 PM
olddog's Avatar
Default No one knows - - help.
Have an 05, C6 and it has had headers, Vararam and a tune since 1100 miles.
Developed a high speed burble, not a miss but almost like one and you could feel it: put in new plugs, proper spark plug wires, checked injectors- same thing.
Our dealer is really poor: gave me a VDR and we did see the MAF drop from over 10,000 to about 4800 in a matter of 200 rpm.
Put on a new MAF: same thing. I had a new T-body (OEM) and tried that, same thing. Tried tightening the intake bolts and they may have been one or two flats loose: same thing.
Dealer says you have headers and ram air and we can't help you: told them it has been fine for 19,000 miles so it wasn't that - - any ideas out there as to what is causing this burble at about 6200? (REv limiter is set to 6800 - - it isn't that).
If you think you know all ideas are welcome - - Thanks
John
Old 08-16-2007, 06:39 PM
blade2222's Avatar
try changing air and fuel filters
Old 08-16-2007, 06:41 PM
olddog's Avatar
Both filters are changed . . . neither, to my understanding would cause the MAF to drop as radically as it did.
Dealer is useless!
Thanks for the comment.
Old 08-16-2007, 08:14 PM
VinceTrifecta's Avatar
Can you try putting the stock intake back on and see if the problem improves/goes away?
