STS Help...
STS Help...
Ok I have a T-60 STS, and I have had it for a few months now and I am gettin sick of the clearence issues, I haven't hit anything but I am not happy that the turbo hangs so damn low, I have hear of ppl either removing or hittin the heat sheild of the gas tank to tuck the turbo a few inches into the back of the car...and I am also gonna tuck the intercooler piping and basically any help with clearence issues on sts cars...thanks
i've had the sts turbo for 2 yrs now and never had any clearence issues with the back half of the car where the turbo is. the front is a different story i've bottomed out a few times with the pipe goin to the intake. my understanding is that with a intercooler it would correct this problem cause it's piped a lil different. plan on gettin one down the road and i hope it helps.
With the intercooler the piping is run different but my charge pipe still hits if road is rough or upon really hard stops...fbod front end dive...but I am gonna try and re rout it soon, but I am sure that someone has tucked it...
front end dive describes it perfectly. it definitly can be tucked up tighter with some custom pieces. go to exotic performance plus they did a sts setup for someone and modified the piece ur talkin about. they also have plenty of pics.
If you make a slight bend in the pipe that goes under the K member, it will be on an upward slope, so the lowest part will be right under the K member.
As far as the turbo, you need to clock the housings right and you will have good clearance.
yeah,no probs with the turbo, a couple of snags on the back piping as it goes from the middle to the side of the car. LOTS of probs with the front but that was with pro-kit which is gone now
hey dude, if you wanna see my setup on how i did the STS it sits really high up
the exhaust shop can fab up the brackets and how i had my setup for like 100 bucks
let me know, ill PM you my number again
my car is lowered with springs and I have a fmic no problems in front but the only thing I didn't like about the sts kit was the piece that loops over the diff. so I got rid of that and made it go under the diff. my turbo sits real nice off the ground and I made a piece when I was puttin the kit on to sit it higher......
