cam questions..
cam questions..
could someone make me a list of everything i would need for a cam swap..i see texas speed has some packages...besides what comes in their cam packages, what all would i need...i know the oil pump but what else...also i see that texas speed has cam packages for 599.00..with those packages what kind of hp are people making...Thanks
thier cam install packages pretty much have all that you "need"
optional upgrades are the ls6 oil pump, timing chain, titanium retainers and things like that.
as for the hp output.....which cam
something like the TR 224 cam will make about 375rwhp with boltons tuned. something like the Torquer 2 will make over 400rwhp, the Trex has the possibility of making 425rwhp
will i need other things besides the oil pump.,,gaskets etc?..also why would someone get the cam that would make less power if they are the same ...and will the torquer 2 have a choppy idle
Restricted User
get an U/D pulley and belts, I also highly recommend a long bolt for install. Dex cool, oil, cam replacement kit for gaskets. If you're going to do it yourself I also recommend crane cam's valvespring compressor and some dowels to keep your lifters up.
