wideband bung location?
The way I figured it was, I want both banks being read, but you also want the bung as close to the engine as possible, so you get a more precise, accurate reading. When I had a Y pipe setup, mine was a few inches after the merge, going in from the side of the pipe.
Ideally you'd want two bungs, one on each bank right after the collector and switch the wideband back & forth (or run dual widebands $$$). This would allow you to see variations from bank-to-bank instead of a mix of the two. Sticking it right after the merge would work fine though, so long as the sensor has no problem staying hot enough.
Originally Posted by jmm98LS1
On my duals, I've got it 8" behind the driver's side collector. I chose the drivers side because it tends to run a wee bit leaner than the passenger side, as to error on the side of safety.
Originally Posted by ls2 bait
is that a general rule of thumb or is that just what uve noticed in logging ur motor?
Originally Posted by TheLS1Kid
Cool, so did you just buy an o2 bung and drill a hole and weld it on?
