how to replace the knock sensors or tell if they are bad?
Old 08-17-2007, 04:19 PM
johnson7454's Avatar
Default how to replace the knock sensors or tell if they are bad?
both my knock sensors are throwing codes and i was wondering if there is a way to check to see if they are bad....the car does have a small miss and really pings on unleaded...found that out the day i bought it but have run nothing but premium since...
Old 08-17-2007, 04:28 PM
tylerdj's Avatar
To replace them you just remove the intake and they're in the 2 holes in the valley cover.
Old 08-17-2007, 04:29 PM
JMBLOWNWS6's Avatar
If I am there I replace both of them at the same time. The PCM will throw a code.
Old 08-17-2007, 05:07 PM
2001NBMZ28's Avatar
Check the KS harness behind the intake first - www.gearchatter.com/viewtopic9148.php
