Idea on what to expect for RWHP for my LS1 RX7
Old 08-17-2007, 04:25 PM
Snyper's Avatar
Default Idea on what to expect for RWHP for my LS1 RX7
Well as some of you already know im in the process of building an LS1 equipped RX7. Ive been helping my friend build his 01 SS camaro for the past summer. Hes just decided he wants to go with a 402 and hes going to give(yes, for free) me his 25,000mile short block complete. What I was wondering is the block already has a 236/236 590/590 112 cam in it. I plan on buying a set of stock unported 243 heads to go along with the stock LS6 intake manifold that he already gave me off the motor...What kinda power should I expect to make through long tubed headers and a true dual exhaust?..I dont plan on spinning the motor past 6500rpms. Also would this setup safely handle a 100 shot? (not sure ill need much more in a 2600lbs car)
Old 08-17-2007, 04:47 PM
Ceissus's Avatar
some have made over 400 with "cam only" using a smaller cam than that.
my guess is 415+?
Old 08-17-2007, 04:51 PM
Restricted User
socmguy's Avatar
400rwhp would be a conservative guess and with a power to weight ratio like that you'll be killing it on the street!
Old 08-17-2007, 05:11 PM
Snyper's Avatar
my guess is 415+?
With LS6 heads?..also would the 100 shot be safe? And is there anything I should add to the stock internals before putting it in the car?
Old 08-17-2007, 08:15 PM
RIDINFILTHY's Avatar
close to 400 and yeah its safe!
Old 08-18-2007, 12:23 AM
Snyper's Avatar
keep it comin..
Old 08-19-2007, 06:53 PM
Snyper's Avatar
uptothetop
Old 08-19-2007, 07:58 PM
o2camaross's Avatar
im pretty sure you'll be fine with even a 150 shot, just make sure you get all the safety switches and a good tune. That thing is gonna fly. There's a body shop around my house called Alex's, and his sons are f-body fanatics. They have three LS1 powered RX7's and all run 10's or better. Alex told me that one wieghs only 1700-1800 lbs. Couldn't imagine being behind the wheel of one, but i would love to.
Old 08-19-2007, 08:18 PM
Nimitz87's Avatar
make sure to upgrade the valve springs and pushrods at the minimum.
Chad
Old 08-19-2007, 09:40 PM
Snyper's Avatar
Chad
I planned on using the patriot .650 lift springs and chromoly pushrods. I dont plan on spinning it past 6500. I would use more than a 100 shot but Im not sure im gonna need it. My goal is 10.99 on a stock motor. If I reach that ill rebuild the bottom end port the 243's and hit it with a 200 shot.
Old 08-19-2007, 10:23 PM
Nimitz87's Avatar
sounds good man, i will do that swap eventually one day.
Chad
Old 08-21-2007, 12:21 AM
Snyper's Avatar
ill let you know when its done. I will have a huge thread.
Old 08-27-2007, 08:24 AM
N21923's Avatar
Remember, your FD has IRS, that'll soak up a few horses. My guess 385hp.
Old 08-27-2007, 09:44 AM
ecetim's Avatar
That's a pretty big cam for an LS1, no? That + stock 243's should net only ~400 RWHP? Kinda disappointing...
(I've been considering the same combo, but with a smaller cam)
Old 09-05-2007, 12:14 AM
Snyper's Avatar
it shouldnt count for that much? And im not sure if ill hit 400rwhp....maybe id be better off with a set of dart 205s?
