Anyone else had probs reading LC1 correctly
I have an LC1 WB hooked to my PCM with the A/C pressure sensor. I am using HPT and logworks to read the AFR. Im using the (Voltage/.625) + 10 = AFR equation with a range of 10 to 18 AFR.
But for some reason my HPT readings is off anywhere from .30 to .60. For example, logworks reads 14.00 AFR and HPT reads 14.60 AFR.
Has anyone else had this problem?
