Cam install, extended wait, lube ideas.
Old 05-25-2003, 08:09 AM
DaleMX's Avatar
Default Cam install, extended wait, lube ideas.
Next week I知 going to install my new cam (TR230), springs (918), retainers, oil pump, and timing chain. After the install the car will have to sit for about 3 months before the initial startup so I知 worried about just using oil on the cam. I fear that most of it will run off before I have a chance to start it up. Can I just use white grease or something else that will stick? Maybe I知 worried about nothing, but any recommendations are appreciated.
Dale
Old 05-25-2003, 08:25 AM
DaleMX's Avatar
Default Re: Cam install, extended wait, lube ideas.
Oops, posted in the wrong section, Can you move this to internal engine please.
Dale
Old 05-25-2003, 10:10 AM
SPANKY LS1's Avatar
Assembly lube should work for that. Can get it from any auto parts store.
Old 05-25-2003, 10:23 AM
needmoremoney's Avatar
I used the LUCUS oil stabilizer part # 10001. It's a VERY thick oil, that can be used for assembly lube. I installed my cam a month ago, and im still waiting for my new heads to show up. Good Luck
Old 05-25-2003, 11:20 AM
malibu350's Avatar
I wouldn't use any of the white assembly lube, what are the reasons you have to wait so long to start your car for??? If you are doing a head swap, before you bolt the heads on dump some oil down the lifter valleys(with the lifters out) or get an oil can and squirt it down in there on the cam. Also I would pour some oil all over the rockers and pushrods before bolting the valve covers on....Just did it with mine and no problem...but then again mine only sat about a day...not months...good luck!!
Old 05-25-2003, 12:26 PM
kick_*ss's Avatar
Not sure why you say not to use the white assembly grease, worked great on my CAM install and some on the rockers and push rod tips.
No problems and almost 20k miles with the cam and vavletrain
Old 05-25-2003, 07:21 PM
DaleMX's Avatar
White grease is what I've always used, but I've never run a roller before.
Malibu350, I building a car from the ground up and wont have the radiator and fuel pump installed until I get a bunch of other stuff done. Belive me I'd love to start it, but alas I must wait.
I had also considered some of the super thick moly additive. Wonder if they make a lithium with moly?
Old 05-26-2003, 01:02 AM
FrankSS's Avatar
buy some install lube from nearest parts store for 2.99 and youll be good to go whenever.....
