Bogging at WOT no power
Ok heres the deal, just had the car at the track and it is acting very goofy. It left the line perfect, but then started to progressively loose power as it when through the shifts, kinda like the trans shifted through all gear right away and locked the converter. It felt like it went right into OD and locked up and wouldn't come out of it. BUt it also feels like it just plain bogged.
My foot is to the floor but the car does nothing, kinda like the computer manually shut off all power to the engine by pulling all timing. A/F is a solid 12.8 to 13.0. ASR was off, I had no flashing SES light, only a p121 code which I have not had fixed yet. The transmission parameters have not been changed other than I raised the lock up MPH by 10mph across the board.
Can a heat soaked IAT cause this type of problem, or is there a BIG issue with the tune. Maybe somebody else has this problem too.
H/C, 3600 stall, 3.73, stock intake TB
