S80 versus S88 on 408
Old 08-18-2007, 11:03 PM
theblur98ss's Avatar
Default S80 versus S88 on 408
Just curious what kind of power differance there would be between the 2 turbos on the same 408 motor. I was set on getting an 88 but I may have a good deal on an 80 come up.
Old 08-19-2007, 01:05 AM
NA$TY-TA's Avatar
Depends on how far you really want to push your set-up...
really and S88 will run out of steam with 408ci if you really lean on it....
Kyle
Old 08-19-2007, 07:07 AM
Websy21's Avatar
Kyle
I think he meant the S80 not the S88
Old 08-19-2007, 10:27 AM
cablebandit's Avatar
i think he meant the s88 he did say LEAN on it!!
Old 08-19-2007, 10:40 AM
Websy21's Avatar
Ya he probably did, your right. I am just not as big of speed demons like you guys I couldn't picture myself maxing it out, well for now anyways, LOL. I am currently piecing my project together and I am going with a 408 and the t80. Mose will say its not enough, but should keep me fairly happy for a while. The guy I am buying it with said he made 800rwhp with it, probably not too efficent though. If I decide I need to upgrade in the future it will be a S88 no doubt. I am not building a race car, pretty much street only, crusier. I'll probably won't go past my lower boost setting on the controller too much. It just depends on your goals, but I think over 600rwhp is enough for a street car anyways. To help answer the poster's question so it doesn't seem like I am jaking here, I think you should state your plans/goals for the car. If I wasn't buying this kit from someone I would definetly start with the S88 if going with a 408. If I do this now I have to buy a new turbo, plus modify my kit. Don't have the money right now anyways. So if you think that you are maybe going to use the power in the future........ just get the S88 now and be done with it. I think that its capabilities would suffice for most. Just my opinion though, good luck. I will be interested with your results since we will be doing similar builds. Sounds like you are going more turbo than me though, you bastard! JK
Old 08-19-2007, 12:05 PM
Let's say an 8 second capable setup is what I'm looking for.
Old 08-19-2007, 12:29 PM
NA$TY-TA's Avatar
Then the S88 for sure if not bigger.
I sold my S88 and most dont know that (they do now)
Because im going with 400+ cubes
The flow of these motors really start to effect back pressure.....
If your serious about running that quick....
Pick a turbo that can work with the cubes and flow of your motor.
Kyle
Old 08-19-2007, 02:48 PM
DanZ28's Avatar
Kyle
Sounds like the new S91 might be a good choice, is this what you went to Kyle .
Dan
Old 08-19-2007, 04:51 PM
NA$TY-TA's Avatar
Dan
I have something special coming.....
Old 08-19-2007, 05:14 PM
Websy21's Avatar
I'd agree, sounds like bare minimum S88 but probably bigger. You mentioned that you had a great deal on a S80 and thought you should take it, I thought that with those intentions you weren't implying a 8 second car. S80 would have a hard time getting into the 9's with those cubes.
Old 08-20-2007, 06:24 AM
Firechikn's Avatar
I bet I know.
Old 08-20-2007, 10:23 AM
LS1TECH Sponsor
DrTurbo's Avatar
The S91 is the new beast.
Old 08-20-2007, 12:39 PM
NA$TY-TA's Avatar
Originally Posted by Firechikn
I bet I know.
Hmmmm who told ya LOL
Kyle
Old 08-20-2007, 05:11 PM
obZidian's Avatar
If i wanted to modify my s85, what is the largest trim/wheels i can go without replacing the housing?
Old 08-21-2007, 11:52 AM
LS1TECH Sponsor
DrTurbo's Avatar
With the cover you presently have, the 88 is the largest you can go. The new 91 now uses a total different cover and flows Mega air compared to the older cover that was the original design.
Old 08-21-2007, 12:00 PM
obZidian's Avatar
how much larger is the new cover designs for the s91? I guess when and if I get bored, I could either sell my old turbo and go S91 or just rebuild the one I have now to a S88.
Hmmm.... but that s91 sure sounds badass... Lol! And I thought I was over dealing with this kind of stuff!
Old 08-21-2007, 12:26 PM
LS1TECH Sponsor
DrTurbo's Avatar
The S91 is a direct fit . Also the turbo does require machine work to use the cover. But nothing that couldn't be done in a few mins on the CNC.
Old 08-21-2007, 12:41 PM
obZidian's Avatar
machine work for a S91 or the S88?
Old 08-21-2007, 03:45 PM
LS1TECH Sponsor
DrTurbo's Avatar
Yeah....both require machine work for the new cover.
Old 08-22-2007, 03:33 PM
CrazyChris's Avatar
Are the new covers out yet? How do you tell the difference between them (88)?
