what is wrong?
Old 08-19-2007, 06:39 AM
hesham's Avatar
Default what is wrong?
i have a 1999 comaro i install mti stage 2R heads and lg x3 cam on my 5.7 engine i have also ud pully and k&n filter and borla catback and MSD coils
all what i get on the dayno is 330HP and 312TQ
need some thoughts
Old 08-19-2007, 06:46 AM
navymitch12's Avatar
it hurts to read....but...
what kind of dyno?
What was the DA when you dynoed?
is the car tuned?
Old 08-19-2007, 06:50 AM
hesham's Avatar
what is killing me that i swaped form patriot stag2 and mti r1 cam and the car was running 393HP and 380TQ
its a daynojet and the car is tuned
Old 08-19-2007, 10:13 AM
gts500's Avatar
hesham do you have your dyno graph? the old one and the latest,maybe it would be understandable if you show it.
Old 08-19-2007, 06:03 PM
hesham's Avatar
no but i can get it tommoro i will change the MSDs and return the stock coils
i have a 280 PSI fuel pump and 30# injectors my timing is around 23#
and i can't go higher becouse i will have konck.
my A/R ratio is aroun 13.2 its not that lean but i dont know it is the problem
Old 08-23-2007, 05:38 AM
hesham's Avatar
i found my problem it was the MSDs coils i will post my dayno with the MSDs and after i removed them
and when i finish my tune i will post my final results
Attached Thumbnails what is wrong?-coils.gif   what is wrong?-without-coils.gif
Old 08-23-2007, 07:52 PM
hesham's Avatar
i have 1.75 rockers should i install them?
what about clerance?
any thoughts?
Old 08-24-2007, 11:31 AM
hesham's Avatar
so is here any one have the knoledge to answer my question?
