Teaser video of Whipple 3.3L in C5 Z06
Old 08-19-2007, 05:19 PM
rjw
rjw's Avatar
Location: Tinker till it blows, then back it off a notch, maybe!!
Default Teaser video of Whipple 3.3L in C5 Z06
Here is a little teaser video of the car idling and revving.
I had just washed the car, so there is some water in the tailpipes and on the engine.
In the engine shot video, the vacuum pump is making most of the noise
The video from in the car is with the passenger's door slightly open. windows up.
http://home.att.net/~my03z/IDLE-REV.wmv
Old 08-19-2007, 05:40 PM
99Z28LS1's Avatar
I LOVE THE VID...... but must now see a WOT
Old 08-19-2007, 05:42 PM
Websy21's Avatar
Thats awesome, take her for a spin and get another vid. Nice set up man!
Old 08-19-2007, 05:49 PM
rjw
rjw's Avatar
Oh..here is a little video of some load testing on the dyno
http://home.comcast.net/~badassc5/RJW.wmv
Old 08-19-2007, 06:55 PM
98turbls1's Avatar
awesome man... PLEASE make one of a WOT run on the street...
Old 08-19-2007, 08:46 PM
2MuchRiceMakesMeSick's Avatar
Thats different
Old 08-19-2007, 08:57 PM
ninetres's Avatar
Sounds NASTY!!!!
How much boost ya runnin?
Old 08-19-2007, 09:57 PM
DocT's Avatar
That's a sexy sounding beast man! However, I agree with the above posters, I wanna see some WOT on the road!
Old 08-19-2007, 10:01 PM
rjw
rjw's Avatar
Just moving slowly at this point...6.5 psi 543rwhp/532t @ 9.4 afr!!!
The run on the dyno was just a tuning run, checking things out
Will only shoot for 600 rwt and whatever the hp goes to, due to clutch and stock bottom end.
then, if things go well, in goes a forged 346 and stronger clutch..shoooting for 800rwhp/800rwt or better.
rjw
Old 08-19-2007, 10:03 PM
rjw
rjw's Avatar
It might not be legal...
Coming soon...
Old 08-20-2007, 12:34 AM
venom ws7's Avatar
6Psi and 532rwtq WOW With more boost Can you say
Are you on stock bottom,heads,and cam? Full mods list PLZ
The car is sick and gonna be even more sicker with more boost.
Old 08-20-2007, 12:54 AM
rjw
rjw's Avatar
The following is from the original thread on this forum .This was posted on Friday 8-18-07
Details: (for those not following my project)
2003 Z06 Ls6 stock bottom end, afr 205's (out of the box), LG G5X1 cam, Kooks 1 3/4 and Borla 2 tip stingers. WITh CATS and all smog equipment hooked up and functioning.
These are 3 runs that I managed to get in late this afternoon. You can see how I am moving extremely slowly and monitoring a lot of things as I go, so NO BIG numbers just yet.
Setup was:
4 to 6 PSI sc pulley (shows 6.5 psi on dyno and 7.5 on road)
12 degrees total timing
97F ambient (Probably well over 100F in shop no ac, 2 floor fans blowing at car)
AFR's on MY wideband were in the LOW to MID 9's. The dyno sheets show a point leaner, which is normal when checking before and after cats.
Please remember, these are INITIAL results and you can see how things are moving as I lean it out a bit at a time.
Also, this is on a Dynomite dyno, not a dynojet
Final pull was around 545 rwhp/532 rwt, SAE corrected
Sorry that we didn't move the cursors to the peak hp and torque numbers, we were in a hurry to go home.
I will be going back either tomorrow or Tuesday looking for some MORE serious numbers.
btw: here is the link to the original thread
https://ls1tech.com/forums/showthrea...5&page=1&pp=20
Old 08-20-2007, 01:02 PM
DanZ28's Avatar
Looking good!
Awsome torque curve, if you call that a curve .
Curious as to what it would be if you started the run at 2K RPM?
Dan
Old 08-20-2007, 01:07 PM
rjw
rjw's Avatar
Originally Posted by DanZ28
Looking good!
Dan
Pretty much the same
I was having lean out problems when whacking the go pedal, so I eased into it. problems solved now, so Tueday the new numbers should show from 2k.
Old 08-20-2007, 05:31 PM
obZidian's Avatar
umm.... there is no curve in that torque curve. I call B.S.!!!!! Impossible!, must be cg'd!
nah, looks and sounds amazing! If you don't mind, did you have to do any kind of unusual modifications when installing the blower of was it pretty much straight foward?
Old 08-20-2007, 08:19 PM
rjw
rjw's Avatar
Total re-design of the IC , etc.
Unless you want it sticking way out of the hood.
btw: they include a demo version of photoshop with every whipple blower
Old 08-22-2007, 07:57 PM
SScott's Avatar
I love how quiet the blower is. Nice nice nice.
Old 08-25-2007, 10:16 AM
MagiC5's Avatar
how much was the set up if you don't mind me asking?
Old 08-25-2007, 12:37 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
very impressive numbers for that much timing and air/fuel, but what i want to see is the hood that fits over that thing.
Old 08-25-2007, 05:09 PM
rjw
rjw's Avatar
The hood is my maggie hoos from aci...it fits fine, with a little mod to it at the cowl, but no biggie
Quick Reply: Teaser video of Whipple 3.3L in C5 Z06
