1998 Camaro Z-28 stroker in montreal
Red and fully loaded except leather. Fast and reliable. 437 HP at the rear wheels with the old heads and cam. I expect more from the current setup. I have more than $45K total in the car. The car has a brand new clutch , slave and flywheel :23lb billet flywheel, LS6 slave and new Spec stage 3+ (SPEC SC093F ) rated to 850 ft. lbs. Car has trapped at 123.7mph+ and has run mid 11s on a 4400RPM launch with a 1.75 60' . Could probably do very low 11s with a different suspension setup. Very streetable and could be easily used as a daily driver. I have driven from Montreal to Wildwood NJ several times with it and got 25MPG on the highway. 25K miles on motor and differential. 80K miles on chassis. Asking $15,500. cdn FIRM Pictures to come soon. Steve 514-894-4338 , 450-686-0299
Here are the modifications.
1) SLP oversized radiator
2) MTI air filter lid
3) Greddy catch can
4) Ported throttle body
5) K&N air filter
6) Lunati 383 stroker kit, EA035-383 (Lunati LS1 383 Rotating Assembly, 3.903" Bore, -8cc Reverse Dome Forged Pistons, 4.000" Stroke, Pro Mod 6.125" Rod Length, 10.6:1 compression ratio )
7) 2002 LS6 block and valley cover.
8) Rollmaster double timing chain w/ Torrington bearing
9) Comp Cams 242/242 113+4
10) Patriot stage 2.5 heads with crower double springs 2.02/1.57
11) Yellow Terra 1.7 Roller rockers
12) Kooks stainless 1 7/8” headers
13) Cutout
14) Magnaflow stainless catback
15) LS6 intake
16) Strange 12 bolt diff with super posi and 3.73 gears
17) SLP linelock
18) Short shifter
19) IBM 733mhz with Autotap and LS1 edit
20) BMR suspension (front and rear torsion bars, control arms and relocaters.)
21) KYB 8 way adjustable shocks
22) OEM Camaro SS hood
23) OEM Camaro SS spoiler
24) ZR-1 aluminum mags
24 Extra rear wheels with ET Street slicks.
25) Eibach springsArp head studs
26) Arp main studs
3) Greddy catch can
5) K&N air filter
13) Cutout
15) LS6 intake
17) SLP linelock
18) Short shifter
26) Arp main studs
