any one using a ported fast 90 with a procharger?
im building a 402 ls2 and i already have a ported fast 90 from vengeance racing and a NW 90mm Tb. im looking to get a procharger from EPP and i want the f1 head. will my fast 90 hold up or do i need to use a different intake manifold. and witch one?
TT-TECH Veteran
If you have it use it.I have only herd of a couple cracking under Extreme boost 25+ lbs and the leak issues I have seen when not properly installed, but not a comon problem just most FI people spend the $ else where because the LS6 has done the job very well for a long time etc...
I read of a few guys having problems past 20psi. I never plan on going past that psi and liked the idea of the direct port option on the fast and it does take the 90 tb.
I would also think it might be beneficial on some bigger engines like the 427 mabye even 454 I might go with.
If you have it I would run it, bigger CID and a bigger blower would probably see some benefit. I ran a 90/90 for a while and didnt see much difference but that was with smaller heads and cam and sold it off so I could buy a bigger blower which most definately made a difference I have read about some leaking issues with over 20psi but mine was fine at 14-16psi.
