Anyone running cam only or H/C with stock oil pumps??
Just wanted to see if any of you guys are running a stock oil pump LS1 LS2 or LS6 on a cam only or H/C car and to see how your holding up. It just seems like a ported oil pump is over kill for a motor thats spinning up to 6600rpms?
ROger
ROger
I called Lingenfelter's on this issue. I was told that unless you had a crank with additional clearance on the bearings, you didn't need a ported oil pump. So for your setup it really depends on if the stock pump is worn out and should be replaced.
