Help me after intake install throwing a code!!!
I installed an LS6 intake over the weekend. I also changed the valley cover to an LS6. Ran the car for about 5 minutes and it then threw a code after it seemed to relearn the computer. I drove straight to AutoZone and there tool says it is most likely in this order:
#1 - Knock sensor
#2 - Knock sensor wiring
#3 - Knock in the engine
#4 - Fuel pressure
Now the one knock sensor had a little bit of corrosion or white rust on it, but what are the chances it went bad right after i installed the intake. Could the new intake throw the A/F ratio so far off to throw this code?
what do you guys think?
#1 - Knock sensor
#4 - Fuel pressure
