Can i run my oil return for turbo to a valve cover?
Old 08-21-2007, 11:45 PM
SPRAYED 01's Avatar
Default Can i run my oil return for turbo to a valve cover?
Im setting up a single turbo forged ls1. Its a precision 67 turbo. The oil feed is tapped in above the oil filter housing. I bought the kit used a the previous owner said the return would need to be tapped into another part of the oil pan.
I had an idea, if its a return why not just run a line up to the pass valve cover where i have the pcv port blocked anyway and return oil into the valve cover. That way there is no more drilling the block.
If this has already been done a million times, sorry im new in the FI game. If there would be any problems please let me know.
Thanks
Alex
Old 08-22-2007, 12:19 AM
TT-TECH Veteran
Inspector12's Avatar
Yeas you can with a scavenging pump or unless it is higher than the vavle cover? Better off to gravity drain it to the pan if possible.
Old 08-22-2007, 05:15 AM
EPP
EPP's Avatar
These engines already dump a lot of oil back through the heads, I'd return the oil through the oil pan. Bob
Old 08-22-2007, 07:50 AM
SPRAYED 01's Avatar
Wont the return still be under pressure and be able to push it up to the valve cover.
Bob, wont returning the oil to the head still be the same, it going to go down to the pan any way right?
Old 11-25-2016, 11:32 PM
Ogoz23's Avatar
Im wondering this myself , my engine is all put together and the last thing I want to do now is take the oil pan out to install a fitting .
Old 11-26-2016, 01:08 AM
ScottyBG's Avatar
Gotta go to the pan unless your entire turbo is higher than your engine. If the return is under enough pressure to push it back up to your valve cover that will be enough pressure to push oil past your turbo seals. If you don't you risk taking the oil seals out of your turbo. Oil will go past the seals and you will smoke something terrible. I've seen others make this mistake. Take the pan off and drill and tap it now, way easier than after you have it all in the car and realize that's what you need to do. Best advice you'll ever get on this one.
Old 11-26-2016, 01:34 AM
pdxmotorhead's Avatar
The oil coming out of the turbo if its got bearings, is foam at first, the return line should be as large as possible and as steep as possible for as long as possible. Any back-pressure on the return is going to back oil up against the seals and reduce their life.
YMMV, this is just my experience road racing them. May not be as critical if you not doing long sessions like we did.
Old 11-26-2016, 02:56 AM
8.Lug's Avatar
The turbo is not pressurized with oil. There is a restrictor with a very small hole that only allows a small dribble of oil into the center housing simply to lubricate, it's not like a crankshaft bearing that's designed to hold loads. Turbos are not sealed units. If you were to run a return line higher than the turbo - or even level to the turbo - the oil wouldn't return at all, it would go into your exhaust and intake. That's why not only is the line supposed to run as straight down as possible, it also needs to be MUCH larger than the feed line because gravity is doing the work, not oil pressure, and there needs to be as little amount of resistance as possible for it to drain.
Old 11-26-2016, 03:44 AM
Ogoz23's Avatar
Ok i will weld on a fitting to the pan , As far as the fitting is a 10an to 1/2 npt good enough or a 10an to 3/4 npt better .. what fitting are you guys running?
Old 11-26-2016, 04:20 AM
ScottyBG's Avatar
Mine is -10 to 1/2 NPT. I think that is most common.
Old 11-26-2016, 12:35 PM
SPRAYED 01's Avatar
Man I posted this 9 years ago! I feel so embarrassed that I asked this knowing what I know now.
Just goes to show no question is a dumb question.
Alex
Old 11-26-2016, 03:07 PM
gtfoxy's Avatar
IIRC the 80 Trans Am I had that had the 301 Turbo had the return run into the VC... Maybe it was the valley... Had one back in 93-94 so it's been a while. I did a 400 Pont. With a turbo so my familiarity with the factory set-up was the day it took me to rip it all out. I know the early Non-IC Buicks just ran them to the valley, had a couple of those as well.
Old 11-26-2016, 04:50 PM
Ogoz23's Avatar
Is this spot ok to weld a fitting for the return? Right where the yellow dot is.
Old 11-26-2016, 05:17 PM
stevieturbo's Avatar
Yep..
Old 11-26-2016, 07:24 PM
truckdoug's Avatar
thats where mine is. some put them in the timing cover too.
that might be ideal for you since you wont have to pull the motor again. just pop the balancer & timing cover off.
Old 12-08-2016, 12:00 PM
Ogoz23's Avatar
I need to change where I'm putting my return do to the crossover pipe being in the way , can I put the return I the front of the oil pan where I'm pointing ?
Old 12-08-2016, 12:53 PM
If you want to, yes
Old 12-08-2016, 01:09 PM
Ogoz23's Avatar
Is it a good place ? Or that would be a problematic place as far as the oil backing up
Old 12-08-2016, 01:18 PM
If it works physically for the install in the car, then I wouldnt see any problem with it.
As long as the turbo has a good gravity drain to that location..again no problem.
Old 12-08-2016, 05:52 PM
The BallSS's Avatar
I'm running a low mount Huron Speed V1 AC kit and have my turbo drain line entering the pan right above the drain plug.
The drain line is almost flat but doesn't smoke unless I'm on the brakes hard down an incline, like say down a freeway off ramp from 100+ mph lol.
Even then its a small amount of smoke for a few seconds.
I also attribute it to working as well as it does because I use a MM PCV catch can.
Due to the kit design placing in the timing cover or pan front wouldn't and fortunately this has worked out very well.
Quick Reply: Can i run my oil return for turbo to a valve cover?
