want to know what all needed
ok i got the AIR DELETED so i can remove it. so what all do i need to remove it now i know you need the two block off plates is any thing else needed? i would use the search but its not working out for me right now.
Just the block off plates. Remove the pump from under the driver's side headlight. Then follow the big black hose up to the next things that must be removed. There is some sort of distribution block for the air that sits on the driver's side of the motor way in the back then each AIR hose comes off of that to the headers/manifolds. Remove all that, and then use the block off plates and you should be set.
I too am removing the AIR system in one of my cars, but I do not have a set of block off plates--where is a good place to get them?
Originally Posted by tylerdj
I had to plug a vacuum line that went behind the intake.
Originally Posted by Ceissus
There's no vacuum line associated with the AIR pump....is there?
It was the same one that svodave is describing.
Originally Posted by fuseone
tyler what year was the car you removed it off of?
