Do I have to resurface flywheel/change bolts when changing clutch?
Internet Mechanic
Originally Posted by Vetal
I don't have flywheel bolts now, so - should I take off flywheel, resurface it and reuse old bolts, or should I just leave flywheel in place, without taking it off to resurface?
Not resurfacing it can lead to uneven clutch surface and premature wear if not out right failure
Think it's too risky without resurfacing?
Its not a frigign myth, its physics, think about it and picture in your mind what an uneven flywheel will do to a flat clutch disk.
Just find the time for a resurface, it is well worth it.
Originally Posted by brad8266
Go ahead and try to shortcut it, youll be one of the typical people here that starts a thread about whatever brand clutch you buy being a POS, but really it will be your own fault and I will delete your silly thread when you post it.
ITS HURT!
i would just replace that thing but a resurface might work...
as for the top bolts there are a few things the swival sockets with the socket right on it
or open end wrench from the top might get it loose then use the 1/4"
one way from under the hood kinda works.
another idea that might kinda work would be to use a jack to apply some slight pressure to the front of the crank on the dampener to get the motor mounts to flex a little and give you some more room.
but that flywheel needs to be at least resurfaced but i would just buy a new one if you got the money
