FI-SDOL- IAT and ECT ve mulitipliers
Old 08-22-2007, 05:31 PM
7 Second Club
ty_ty13's Avatar
Default FI-SDOL- IAT and ECT ve mulitipliers
i have a COS with 2 bar from efilive....
when using the IAT and ECT mulitipliers for desired AFR throughout all IAT's and ECT's what is the basic example?
(ie) higher IAT's mean less fuel is needed
(ie) higher ECT's means more fuel is needed
and vice versa
i hope that made sense but can some one help me out on that.
Thanks,
Tyler
Old 08-22-2007, 05:32 PM
7 Second Club
ty_ty13's Avatar
and can some one post some screen shots of what mulitpliers they use throughout the temp. ranges.
thanks,
Tyler
Old 08-23-2007, 12:50 AM
RedHardSupra's Avatar
airmass=VE*cylinder volume*MAP/(R*TEMP)
TEMP is blend of IAT and ECT. when either one of them goes up, TEMP goes up, and thus airmass goes down. if the blending between IAT and ECT was set up perfect, the multipliers should be theoretically not needed. but than again, i heard some well sourced rumors that even with the blending perfect it's not enough, that's why the multipliers are there.
the real problem is to figure out if the change in airmass comes from change in VE or TEMP estimation. one equation with two unknown has an infinite number of solutions after all...
Old 08-23-2007, 07:12 AM
7 Second Club
ty_ty13's Avatar
i do understand the fact that when every air is heated (higher IAT) it is not as effecient as when it is at cooler temperatures... and i also understand that when a motor is heated above 190 it starts to take a dip in performance also meaning its not as effecient either....
im wondering if some one can manipulate these IAT & ECT tables enough to make a SD OL car drive/start/cold idle like a MAF car.
Old 08-24-2007, 07:35 AM
7 Second Club
ty_ty13's Avatar
what about whenever the car is on a cold start with low ECT and low IAT's the first 3min that my car runs it needs alittle help since i have no IAC valve (i welded up my TB and set it like a carb) it idles at about 600rpms for a little while.... would more fuel or less fuel be desireable on these cold starts... im not worried about getting the rpms higher for the first 3min or so because i understand that I would have to have a IAC valve to open for me... i just want a crisper idle
Old 08-24-2007, 09:03 AM
Frost's Avatar
why would you weld up your IAC and "set it up like a carb"? What does that even mean?
Old 08-24-2007, 10:19 AM
Moderator
jimmyblue's Avatar
I've thought about adding a couple of drill bores and a
taper bleed screw as an alternative to TB blade drilling,
to make an adjustable baseline air path. Not that I need
it but I can see how to do it on a stock TB casting. Not
a big fan of computer controlled idle myself, it tends to
"think too much" and overreact.
If I could find a 85mm side-draft carburetor that fit up
to a Professional Products intake you bet your *** I'd
give it a try. Rig the IAC to only comp the air based on
the air conditioning clutch voltage and you be done.
Old 08-24-2007, 02:16 PM
7 Second Club
ty_ty13's Avatar
believe it or not after the motor has just little bit of heat in it 130*F+ the car idles the best it ever has even after throttle blips decels or anything like that...
Old 08-24-2007, 02:17 PM
7 Second Club
ty_ty13's Avatar
that means the IAC hole in the inside of the TB has been welded/sealed and now i control the idle rpm based on Throttle blade position...
Old 08-24-2007, 02:24 PM
if the car idles well at one ECT but not well at another, it means either OLFA is commanding the wrong AFR target, or your RAF needs to be redone.
Old 08-24-2007, 03:43 PM
7 Second Club
ty_ty13's Avatar
with no maf, raf is not there... what does olfa stand for.... sorry
Old 08-24-2007, 06:39 PM
really? cuz i could've sworn that changing RAF influences my idle and i've been in SD since '05
OLFA is the Open Loop Fuel Adder, it's kinda like PE, but usually used during cold starts, that's why it's ETC referenced.
Old 08-25-2007, 08:33 AM
7 Second Club
ty_ty13's Avatar
hot damn..... i need to check out those two tables then...
Old 08-25-2007, 11:33 AM
Frost's Avatar
With base airflow setup properly, throttle blade stop poition set, commanded AFR met, sometimes IAC counts vs. effective area tweaked, and throttle cracker and follower set, I have gotten around 80 of these boogers to act just like they should and never had to mess with IAC outside of software. But if what you are doing works for you...
Old 08-26-2007, 09:17 AM
7 Second Club
ty_ty13's Avatar
im not gonna say its the bestest acting stealth street car or anything.... but as soon as the motor gets around 140-150 degrees it acts fine.... and im fine with that because its not a daily driver.... but even when the car was a daily driver i'd always wait for the ECT to get up to the same temperature any ways.... so oh well...lol
Old 08-26-2007, 10:34 AM
SSpdDmon's Avatar
If he's running the car without an IAC, than the RAF (Desried Idle Airflow) table, cracker, follower, etc. tables are all useless.
The only thing he can do to improve the drive-ability and startup performance now that the IAC hole has been filled in is to try and swap in a C5 drive-by-wire setup. Then, the TP% of the blade is controled by an electric motor and he can have the idle control functionality back.
Quick Reply: FI-SDOL- IAT and ECT ve mulitipliers
