should i replace my timing chain
Old 08-22-2007, 11:08 PM
99DWPTA's Avatar
Default should i replace my timing chain
on a budget.
putting cam in car here soon.
230 236 110 lsa
putting in katech ported oil pump.
car has 70000miles
DO I NEED TO REPLACE THE TIMING CHAIN OR NO?
Old 08-22-2007, 11:10 PM
99DWPTA's Avatar
and if i do have to replace it can i get away with a oem ls1-ls6 timing chain.
car is a daily driver
Old 08-22-2007, 11:53 PM
NviouSS's Avatar
go buy an ls2 chain for $35 or so.
Old 08-22-2007, 11:56 PM
Tainted's Avatar
a nice chain and all is good insurance, but if you really really cant buy a top shelf one, the LS2 chain will suffice
Old 08-23-2007, 12:56 AM
z28ss4me's Avatar
If your swapping the pump, the chain is right there ready to come off, spend the $35 and get the LS2 chain.
Old 08-23-2007, 10:22 AM
99DWPTA's Avatar
thanks guys gonna order a ls2 timing chain
Old 08-23-2007, 10:24 AM
CaMaRo67RS355's Avatar
i like the slp timing chain and oil pump kit kinda pricy but worth it IMO
Old 08-23-2007, 10:30 AM
StevieZ's Avatar
Rollmaster double = peace of mind
Old 08-23-2007, 06:05 PM
98Camarod's Avatar
**** that Rollmaster chain. I attempted to install it, and had to modify the new oil pump, bolts, timing cover and the bitch still rubbed. I took it off and sold it, and I replaced it with a Cloyes hex a just chain. It makes it so you dont have to get exactly perfect and you can move it to the necessary position.
Old 08-23-2007, 06:11 PM
Tainted's Avatar
ya gotta be smarter than the item to put it on
Mine went on no problems, jsut upt the supplied spacers on there and i was good to go
Old 08-23-2007, 06:30 PM
litle88's Avatar
Like you said your on a budget, just get the LS2 and you will have piece of mind. It is inexpensive and it goes right on the stock gears. It is also noticeably thicker than an Ls1. Goodluck!
Old 08-23-2007, 06:50 PM
noah89's Avatar
yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy yyyyyyyyyyyyyyyyyyyy
eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeee
ssssssssssssssssssssssssssssssssssssssssssssssssss ssssssssssssssssssssssssssssss
Part of a cam replacement budget should be a new timing chain.
Old 08-23-2007, 07:27 PM
98Camarod's Avatar
You obviously got lucky. I too used the supplied spacers and the bitch was hitting on the oil pump where it goes to the pickup tube. I know how to read, it's not that hard to follow directions. Are you sure that your's is not hitting, once I ran into the problem I looked and found that it requires modification.
Old 08-23-2007, 08:35 PM
INMY01TA's Avatar
I'm on my 3rd cam and never changed my timing chain. 2001 w/43,000 miles.
Old 08-23-2007, 10:37 PM
5_02ls1's Avatar
mine had double the miles yours does and it was wore the hell out
I went with an oem ls6 pump and chain.....
Old 08-23-2007, 10:38 PM
5_02ls1's Avatar
Default 3 cams
lol damn I thought I was bad for changing **** alot
Old 08-23-2007, 10:43 PM
mvvette97's Avatar
I'm running a 228/230 with the stock chain. I now have 58k on the clock. Stck chain seemed very good condition and since I didn't change the oil pump I just left it.
Old 08-24-2007, 12:05 AM
Tainted's Avatar
used the double roller and a slp oil pump with the spacers and cleared, engine turns voer fine, doesnt hit. something was wrong with yours or some ****. plenty of people have them and dont run into problems
Old 08-24-2007, 02:45 AM
RunNE1's Avatar
I just purchased the LS2 timing chain for my cam replacement install. For some reason, my local dealer charged me 48.00 for the 35.00 part. Must be the Corvette tax.
Old 08-24-2007, 06:29 AM
mr. Jones's Avatar
If the rollmaster chain rubs, the small gear is not on the crank all the way.
it may look like it is
