Question about EGR AIR removal
Old 08-24-2007, 07:12 AM
jhh011's Avatar
Default Question about EGR AIR removal
I installed long tube headers and removed egr and air but i can not remove the piece that goes into the intake manifold or should i just screw something onto it?
It is the little brass piece right behind the throttle body. Here is a pic of what it looks like.
Attached Thumbnails Question about EGR AIR removal-slp30039.jpg   Question about EGR AIR removal-slp30041_a.jpg
Old 08-24-2007, 07:27 AM
g-ryde1's Avatar
for mine i just unbolted and pulled and it came right out and replaced with a freeze plug from your local parts shop
Old 08-24-2007, 08:34 AM
jmilz28's Avatar
That's what I did too. You should be able to find the part number in the sticky above if search isn't working.
Old 08-24-2007, 08:51 AM
jhh011's Avatar
I bought the freeze plug but i cant get that brass piece out i tried pulling on it and twisting it off. What did you guys use to get it out?
