Bogging..feels like no fuel is getting to the engine
Lately after i start up the car and start driving the car hesitates when i start to give it gas feeling like there isnt any fuel going to the engine...bogging real bad so i let go of the gas and then press it again...it only does this usually right after starting up the car...
any ideas would be greatly appreciated thanks....
also what would happen if the knock sensor went such as due to headers (other possible problem)
thanks
thanks
ive had the same problem... check your grounds, especially the one behind the driver side head. you give it gas, the motor moves/shakes pulling on the wire... it might be loose or corroded somewhere...
had a sim problem a few weeks ago, changed both O2s and it still bogged and kicked flashing SES light.... Checked all the plug and wires and as I got to number 8 coil I touched the wire and it fell off the plug (DUH) hooked it all back up and no problems since
