Missing/spuddering problem, need help!
For some reason my car feels like it is missing or something. When I am accelerating it sorta spudders and the service engine light flashes. I took it up to the dealer and they hooked the scanner up to it and said it was throwing out O2 sensor codes. So I replaced the O2 sensors, took it to a auto part store and had the codes cleared out. Problem still exists. So next I changed the spark plugs and wires. Problem still exists. I really have no idea where else to go with this. The car has head, cam, full exhaust basically the whole nine yards. Any suggestions would be greatly appreciated. Thanks
A flashing SES light means there is a serious misfire. Could be one of more cylinders. I would first invest in your own code scanner, you can get an Actron one from your local auto parts store for around $100, its an invaluable tool to have. Then hook it up, and see if you can pinpoint which cylinder(s) ar misfiring. Then you can swap the coil packs between 2 cylinders, and see of the misfire changes to another cylinder. That will tell you if you have a bad coil pack.
Start there, and see what you can find out from that.
Originally Posted by blueZ28beast
Well we hooked it up to the scan tool at the GM dealer after it had been doing this and it showed none of the cylinders had missed. So any other ideas? Thanks
Originally Posted by ONEBADASSWS6
Thats weird...a flashing SES light indicates a misfire. I've never heard it meaning anything else. Basically its telling you that you have a misfire that is bad enough to damage the catalytic converters. Not sure what to tell you then.
Another thing to do is use a little bit of dialetric grease on all of the boots of the spark plug wires, i know I had a wire arcing once, and it was a pain in the **** to find, until the ceramic of the spark plug had burnt off.
