Wiring Pinout Needed! Trans Sensor...
The problem is that your original unit was wired up for 2nd,3rd,and 4th pressure switches and also the lockup solenoid. Even though your computer is old so to speak, it might throw a check engine light if the trans is not wired correctly. The trans that you have now will work but like I said I'm not sure how the computer is going to react. A painless kit is an easy solution to get lockup to work or get your trans built so that it is done correctly. Where did you get this trans? If it was from a shop did they know it was a 93?
If you are having a no start/cranking issue after a trans install I would be looking at a couple things. Verify that you do not have any wires pinched in between the block and the bell. Also verify that all the wiring to the starter is ok. If that all seems ok, with your foot on the break, turn the key to the crank position and move the shifter through all ranges. See if that makes things happen. These are all things that can be missed on the install. Might take a look to make sure that something did not happen on the install. Vince
LS1Tech Sponsor
You can do that and it will be fine or you can just wire in the outside plug closest to the front on the trans and you will have lockup.
I honestly wish someone GM or others offered that pulg for the 93 but unfortunatly being a one year only they do not.
__________________
