1st time 1/4 time
1st time 1/4 time
Well would have like to hit 13's but guess its not too bad considering it was my first time at any track and with 2.73's in the rear.
1st run 14.20 @99mph
2.134 60'
2nd run 14.32 @98.10 mph
2.174 60'
I am thinking a nice set of LT and a fat stall...soon..........
2.134 60'
2.174 60'
Originally Posted by Jon94Z
Those are some decent times considering you have 2.73's.
I have a set of 3.73's on my list,
I am pretty sure i have a bad egr valve or bad 02 sensor also , so this may have hurt it, also i never raced before ever, reaction time was .796 and crapy 60' time also
It was very humid at the track and quite warm , my second run i ran against my brother, 02ss A4 I matched his 1/8 mile time but he beat me by .5 in the end 14.3 vs 13.8
Originally Posted by LT1Falcon
actually the 02 doesnt have any effect at WOT and the egr shouldnt matter either if it is stuck closed
Originally Posted by Schweet97Z
i think those times are about right.
hes got a few mods, ide say you should be able to hit at least high 13's. get some LT's, that should help a lot with your setup
2.134 60'
2.174 60'
Get into the 2.0/1.9 or lower
You already there, its just the launch bud
My freind was cutting 1.9s 1st time out and on allseaons, with hardly any prep! Just work on the launch
2.134 60'
2.174 60'
no offense, but i dont know how you can say that. i thought most stock, good running, f body cars run low to mid 14's... 100% stock.
I ran a 14.0 @ 99 with Longtubes,ORY, SLP Loudmouth at the time, CAI, Wires, Plugs, and Tuned. You cant compare a 2:73 geared auto car to a 6 speed 3:42 geared car. It also does consist on tracks, altitude, track prep, 60ft times and driver. But i could not for the life of me break 14.0 on street tires. Now a nice sticky tire, would drop the 60's which would then increase the ET.
well if the 02 is bad it could be causing that at idle and cruising, just not at WOT
true true. still i think he could break into the 13's. try again another night. a little practice always helps even with an a4.
Originally Posted by Formula350
Most of those times for low 14s I'm sure are with 3.23+ gears. He doesn't really have any power adding mods. So keeping that in mind and this is his first time ever (not the best 60'), I think that's right on.
hes got more power adding mods than you
