increase in throttle response
Well, a ported throttle body will help out with your throttle response, as well as free up a few more ponies. Lightweight flywheel will get your engine revving faster, although I wouldn't recommend one of them unless you don't plan on going to the strip.
Originally Posted by Kratos 2250
whats the reason for the lightweight flywheel bad or something
What MM are the throttle bodys from factory? I've seen some TB's advertised as 80MM and 90MM I think....but wasn't sure how much to go. On my Z28, the factory bore is 48MM and I upgraded to a 52MM, I noticed alot in thottle response. So, what MM should I go with on my TA?
